07-11-2024 11:30 AM - last edited on 07-11-2024 02:46 PM by computergeek541
I can’t enter the authentication code because I don’t have access to public mobile number only the data works,
it won’t let me send to email,
im stuck I need to buy more data please help reset my account so I can login
07-11-2024 11:54 AM
hi @Cyb1017
unless you purposely remove the phone number from Eversafe, the code would NOT send to email FIRST.
anyway, you saw that I suggest you to message support agent if that does not work?
07-11-2024 11:49 AM
that’s what I’m trying to tell u, I login, it sends. Code to my Email FIRST,
then It sends a code to the Publicnmobile phone number
which I DONT have access to
i keep contacting support but I can’t login to contact them as IT KEEPS ASKING FOR CODE SENT TO PHONE number
which I Don’t have access to
i am stuck on a Non stop loop
07-11-2024 11:35 AM
Try to connect to public wifi and try login on the PM app to purchase more data.
07-11-2024 11:32 AM
hi @Cyb1017
so, voice and text not work? and data is all used up?
to login My Account, you can send the code to email. click Didn't receive code and then Send email
if you cannot receive code that way, submit ticket with PM agent by message:
