Huawei P20 Lite
kodalux
Can someone tell me if the Huawei P20 lite is compatible with PM in Ontario?  I don't see it in the drop down list.
8 REPLIES 8
@kodalux  That model will work with Public. According to the specs it supports the following bands:
3G WCDMA Bands: 1,2,4,5,8 / FDD LTE Bands: 2,4,5,7,12,17,28
@kodaluxIf it had been with Fido before and has been unlocked, then it will work with Public Mobile.
kodalux
It's actually my son's old phone he no longer uses...he was with Fido.  So I'm assuming it should work then?
kodalux
Model is ANE-LX3
geopublic
@kodalux  Do you have the model number?
popping
@popping wrote:
Koodo and Telus were selling Huawei P20 Lite to be used in Telus network.  Canadian version should work wiht PM.  It is locked to Bell or Rogers, you need to get it unclocked before using with PM.
If you have a dual SIM version (i.e. non Canadian version) , it may not work with PM.  You can test it by borrowing a Bell, Koodo, Telus SIM card from friends.
popping
GinYVR
@kodalux If the phone is a Canadian model, then it would work.
