03-21-2019 11:00 AM - edited 01-05-2022 03:51 AM
mine says can't activate Visual Voicemail, try again.
I am using Google Pixel XL.
Joining Public
03-21-2019 03:45 PM
@srlawren wrote:
@sandpublic wrote:VVM is only available for Telus accounts for an additional monthly charge. Unfortunately it's not available to PM customers.
@sandpublic do note that Koodo customers (post-paid for sure, not sure about prepaid but likely not) have access to Visual Voicemail as a recurring monthly add-on (it recently went up from $2 to $5, which is a bit steep unless you really live in your voicemail.)
Noted, with thanks.
03-21-2019 03:42 PM
03-21-2019 01:09 PM
@mimmo wrote:this is one of the several possible workarounds for visual voicemail:
install fongo, and forward your missed calls to your fongo # then I think they have a visual voicemail type of interface.
Fongo can be setup to send a recording of each message to your email address.
03-21-2019 12:39 PM
+1 for YouMail.
PM offers free call forwarding so you will not pay extra to use it, and on their free plan you get 10 transcriptions per month + telemarketer blocking (very good service, works 99% of the time), as well as personalized voicemail greeting per caller.
Service is awesome, I was on them even before I was with PM.
03-21-2019 11:24 AM
03-21-2019 11:13 AM
03-21-2019 11:08 AM
Public Mobile does not offer Visual Voicemail or any other type of premium services.
Do look for VoLTE, or VoWiFi either.
03-21-2019 11:07 AM
It's not offered by Public Mobile, but I have read about 3rd party programs like YouMail being able to have it function to a certain extent.
You would have to do a little digging for info. I have seen posts about it, but they are older and I do not want to give you old info...
Good luck 🙂
03-21-2019 11:06 AM
@sp1826 wrote:mine says can't activate Visual Voicemail, try again.
Visual voicemail is not offered by Public Mobile.
