How to change email
Itstonyadawn
I am trying to log into my account to top up and I can’t because I no longer have access to the account email and it won’t give me the sms option to verify my account. Help!!!
2 REPLIES 2
@Itstonyadawn
If your account is suspended, you can only get the 2FA code sent by email.
What you could do is to purchase a voucher and enter the voucher number by dialing *611 to Activate your account so you can get the code by text.
To have your email change on your account you need to contact a CS_Agent to change it on your account.
Vouchers can be purchased from these locations:
Meow
ONLY agent can update your email,
To Contact CSA-agent there are 2 methods:
Ticket has to be opened through chatbot - https://widget.telus.tiia.ai/publicmobile/publicmobile.html
Having a ticket is preferred way to contact agent as they might respond faster then receiving personal mail.
If opening a ticket does not work very first time, contact agent directly.
- Send a private message to the CSA - agent by clicking (Ctrl+) Here
Agent’s response is usually between 15 and 120 minutes with a ticket. Private messaging might take longer.
Watch for envelope in top right corner of Community page. It will show Number of unread emails.
