2 hours ago
I tried changing my address in my profile, but get an 'invalid address' prompt ... although the address is correct. I can't find any other way to change my address. How do I do this??
35m ago
Yes, this is what I did, and it's a simple address change within the same city - but I keep getting the same 'invalid address' prompt.
2 hours ago
Are you using the PM app? Login on the app then go to Account tab>Manage Profile the edit your address.
If you are changing your address to avoid higher Provincial taxes. You need to pick a new number with the area code for that Province.
