05-19-2018 12:49 AM - edited 01-05-2022 04:48 AM
Hi everyone,
Just curious, how does one become a community moderator? Is this something possible as a member in the forums, or something that should be obtained through a different channel?
Thank you 🙂
05-19-2018 01:23 AM
Plus, you have to be on the ball like the Oracles, they are quick with the responses!
05-19-2018 01:22 AM
Thanks much. That explains it 🙂
05-19-2018 01:11 AM
Community moderators are actually employed by PM. If you are referring to Oracles, there is a possibility to become a part of Oracle group if you put enough effort and commitment to help around this community.
