How to activate US add on?
darjman
So I just purchased the $20 1GB add on.
Ill be be in the states in a few hours.
What do I have to do to get it working once I’m in the US?
im on an iPhone X iOS 11.2
@darjmanwrote:
I’ve done that.
Mia that all I need to do? Can I just use data as normal once I land?
If the add-on shows up in your self-serve account under Add-ons, then you are good to go. All you need to do is Turn on Roaming when you get in the US.
If you need to contact PM Customer Support Agent, Start a Chat to Create a Ticket OR visit the Get Help page.
darjman
I’ve done that.
NDesai
@darjman Make sure you have purchased it twice. First time it adds funds to your available balance, and then second time it actually uses the balance you added to activate the add-on. Once activated, the add-on will show up under Add-ons on the Overview page on your self-serve account.
