12-26-2021 04:18 PM - edited 01-04-2022 04:47 AM
Hello everyone,
I have been trying to figure out how to go in and CHANGE/Update my Password for the PM Community Portal while logged in.
I am fully aware of the Forgot Password process and can follow it but I would prefer to be logged in and change the password as I do with all other services from within the secure portal.
Perhaps the capability is hidden or I am simply missing where we can make this change while logged in.
Thanks
12-26-2021 04:50 PM
@TE wrote:Thanks,
The key was it is under settings/avitar vs profile area where I was looking.
Much appreciated.
sorry just to ask you about that two link i did post in my OP,, you didn't see it or you see it ?
Password Request - Community (publicmobile.ca)
My settings - Change PM Community Password (publicmobile.ca)
12-26-2021 04:46 PM
Thanks,
Much appreciated.
12-26-2021 04:31 PM
12-26-2021 04:30 PM
that link for a Forgot username or password not email what you see..check it out.
12-26-2021 04:27 PM
@Anonymous - OP is asking about changing passwords NOT email used to log into Self Serve.
CSA is not required here.
12-26-2021 04:25 PM
@TE wrote:Hello everyone,
Thanks
@TE - these are TWO totally separate accounts.
Community password if found under your Avatar under MY SETTINGS:
The Self Serve/MY Account password is reset by that Forgot your Password option here: https://selfserve.publicmobile.ca/forgot-password/
12-26-2021 04:24 PM - edited 12-26-2021 04:28 PM
close all Browser and do clear cache and cookies for any Browser,
and try open one Browser incognito mode,
and try Forgot your password visit Here link, and enter your email address,
check your email spam,
or you need to Contact Customer Support Agent by CS_Agent, and Explain your issue to
them can solve your issue, they are nice Service Team they will help you 100%.
and them will reset for you,
Here’s How To Contact Customer Support Agent by Submit a Ticket,
Good Luck....
