10-31-2025
05:02 PM
11-01-2025
01:44 AM
computergeek541
10-31-2025 05:52 PM
Dont copy and paste message, type the message out
10-31-2025 05:32 PM
This is the message using your hyperlink?
Correct the highlighted errors and try again.
10-31-2025 05:04 PM - edited 10-31-2025 05:09 PM
You can use the orange chatbot icon on the lower right to open a ticket. Type submit ticket and select Contact us A Public Mobile customer support agent will help.
You can also send a private message with this link
CS_agent will reply to your Community inbox
10-31-2025 05:02 PM
2 ways depends if you can login My Account
Just open ticket with PM using the Orange Chatbot icon on the lower right. (For 2FA when login, you might need to use email to receive if you cannot receive the text on the phone.) Type the question Submit ticket and select Contact Us to get to ticket open screen
But if you have trouble with open ticket using Chatbot, then message them using this link: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
CS_Agent will reply to your community inbox, check here: https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage
