How do I access voicemail?
Betyourlife
@Betyourlife  - you can use any one of these Voicemail Access number for going to voicemail.
Set one up that is local to your area, if you wish:
https://productioncommunity.publicmobile.ca/t5/Using-Your-Service/Updated-list-of-Voicemail-Access-N...
Hi @Betyourlife   , press and hold 1 and it should call your voicemail.
If it does not work.  try to reboot your phone twice.  (Wait 2 mins in between).  The voicemail number should come down from the network.
if it doesn't work still, you can call your own number from a landline as well
BeachNBeer
@Betyourlife
Your phone should have a fast button. Like dialing 1 calls your voicemail. Does that work?
If not, you can call your own cell phone number and it will bring you to your voicemail or dial ( your area code) -580-4001
Triguy
To access voicemail messages from your mobile device, hold down the ‘1’ key on your phone keypad. You can also access your voicemail from a landline or any other phone line, by dialing your 10-digit phone number, selecting ‘Send’ or ‘Call’ and then pressing ‘*’ to skip the system greeting.
HALIMACS
@Betyourlife
Press and hold one from your device
