03-22-2023 04:38 PM
03-22-2023 04:40 PM
Hi @mdesswein1969 do you mind to share your problem, maybe the Community can help?
to submit ticket with PM CS agent:
at : https://publicmobile.ca/chatbot.
First type Contact,
from the list of , choose "Other"
