01-14-2021 06:46 PM - edited 01-06-2022 01:50 AM
01-14-2021 08:20 PM
Hi @colefelske
See below picture of self-serve landing page for where to see when data renews and how much data left:
01-14-2021 07:21 PM
Log into your account, go to Overview tab/My Data & Add-Ons, View my Usage tab, all the information you need is there.
01-14-2021 07:12 PM
@colefelske If you don't want to keep logging into your self-serve account, you can install data tracking app. On my Android i use the app called Data Witness which also has an option to track based on PM 30 or 90 days plans. It keeps track of 30 days and notifies you when it's about to reach 30th day so that way you know renewal is coming. Public Mobile also sends you a text couple of days before renewal as a reminder.
01-14-2021 07:11 PM
For Android, you can use "Data Counter Widget'. which can track 30 days cycle
There is another on Android called "Data Witness PM" , someone wrote it specifically for PM
01-14-2021 06:51 PM - edited 01-14-2021 06:51 PM
@colefelske Data renews on payment due date at midnight EST. If your next payment due date is Jan 28th. Then on 27th when clock strikes midnight the 28th it renews.
To check your data log into your account and scroll down to my data and add-ons.
It shows there what you have left. Example 760 of 1024. If nothing shows that means you used up all your data.
01-14-2021 06:50 PM - edited 01-14-2021 06:51 PM
Log into your self serve account it's all on the overview page.
