Honor View 20 compatibility
CapZ
Hi friendly people of the internet, just wanted to ask if the Honor View 20 is compatible with public sim cards, couldnt find it in the tool.
Maybe one of you has some experience.
Thanks in advance
CapZ
In the settings tab the model is PCT-L29, in case that's what you mean
cellphoneuser1
Thanks in advance
Which version? Frequency Check says one version has no 3g 1900 and not much LTE support for Public. There are different versions of some models with different compatibility.
mpcdesign
