05-19-2015 10:18 AM - edited 01-04-2022 01:31 PM
Can you tell me please , is it work with your network ? thanks
3G: 850/1700/1900/2100
4G LTE: 700/1700/2600
05-19-2015 03:29 PM - edited 05-19-2015 03:29 PM
Yes, the BLU Win HD LTE from Microsoft will function perfectly on Public Mobile (Telus) network.
05-19-2015 03:05 PM - edited 05-19-2015 03:05 PM
Thanks Cyber , i want to buy this phone , it will be work with PM
http://www.microsoftstore.com/store/msca/en_CA/pdp/BLU-Win-HD-LTE--Unlocked/productID.314281100
05-19-2015 10:22 AM
Public Mobile and Koodo are owned by Telus. Telus and Bell are sharing the same towers.
Telus/Koodo/Public Mobile frequency bands are :
3G UMTS/HSPA (850MHz/1900MHz)
4G LTE Band 4 = AWS 2100/1700MHz
4G LTE-Advanced = 700MHz (not yet launched by Telus/Bell)
To get a new smartphone that will work on Public Mobile, you have to purchase a phone unlocked or locked to Telus/Koodo.
I suggest you Telus (online only), Staples, Best buy, Costco, Walmart or other small cellullar stores.
