Hi there
Global816
I just wanna know if i wanna switch to my old rewards program if its possible?. Please guide
Thanks
1 REPLY 1
TheSterlinger
Please make sure you post all questions related to Public Mobile in Get Support.
https://productioncommunity.publicmobile.ca/t5/Get-Support/bd-p/get-support
In short answer, you cannot; once you are on the public points then there is no way to go back.
