10-13-2017 02:34 PM - edited 01-04-2022 02:45 PM
Hey, so I was planning on purchasing a HTC X10 from Taiwan this coming December but wasn't sure if Public Mobile supports it? Does anyone know? Thanks
10-16-2017 11:06 AM
Great reference @sheytoon
10-15-2017 10:01 PM
Thanks so much for the help!
10-15-2017 10:01 PM
10-14-2017 10:17 AM
Thanks @srlawren! Happy to help 🙂
10-13-2017 09:19 PM - edited 10-13-2017 09:19 PM
Great summary, @sheytoon. I'm bookmarking your reply (https://productioncommunity.publicmobile.ca/t5/Phones-Hardware/Hi-does-the-HTC-X10-work-on-PM/m-p/19...) for future reference.
10-13-2017 05:39 PM - edited 10-13-2017 05:39 PM
You'll need B2 (1900) and B5 (850) for voice calls on 3G.
For LTE, these are the available bands on the network: 2,4,5,7,12,13,17,29,30
You should have B4, B5, B12 (or B17 instead of B12) for minimum coverage.
B2 and B7 will give you faster speeds. The rest are not really necessary.
10-13-2017 02:49 PM
From what I can tell on this site, you will have 3G connectivity. You are lucky if there is LTE here and there.
10-13-2017 02:47 PM
use https://willmyphonework.net/ to check.
You will need to know the model number of the device though
