07-20-2020 09:08 AM - edited 01-05-2022 12:11 PM
Just bought an umidigi a3x can't figure out why it won't connect to data and won't go on 4g. I figure I gotta change some settings. I'm not to good at this stuff so if someone can give me a step by step way to fix this would be a great help. Don't feel like paying for data when it won't even work. Thanks again
07-20-2020 09:14 AM
Hi @jamie905
Here is link from someone else who had a problem.
https://productioncommunity.publicmobile.ca/t5/Phones-Hardware/Umidigi-A3S-problem/m-p/536459#M44213
Hope this works for you!
Welcome to PM 🙂
07-20-2020 09:13 AM
@jamie905 enable data and try sending an mms message. If it fails, change your APN settings to tje ones below.
APN settings:
APN: sp.mb.com
Proxy: Not set
Port: Not set
Username: Not set
Password: Not set
Server: Not set
MMS proxy: 74.49.0.18
MMS port: 80
MCC: 302
MNC: 220
Authentication type: Not set
APN type: Not set
APN protocol: IPv4
APN roaming protocol: IPv4
Bearer: Unspecified
MVNO type: Not set
MVNO value: Not set
07-20-2020 09:12 AM
Does talk and text work fine?
Try rebooting your phone. Network reset.
Check your APN settings
APN: sp.mb.com
Proxy: Leave blank
Port: Leave blank
Username: Leave blank
Password: Leave blank
Server: Leave blank
MMSC proxy: 74.49.0.18
MMS port: 80
MCC: 302
MNC: 220
APN protocol: IPv4
Bearer: Unspecified
MVNO type: GID
MVNO value: 4D4F
