Help
12-13-2018 02:41 PM - edited 01-05-2022 02:47 AM
I need my account to be reset at it is disable! How do get help! I have been waiting on a response nothing!
My Account
12-14-2018 01:42 PM
@ace065 please review this knowlegebase article: How to Get Help
12-14-2018 12:58 PM
@ace065, Public Mobile does provide support. This is where you come for the support. Account related issue are sent via private message(s) to the Moderator_Team.
There is no voice support. This is by design, and as far as we all know here, this isn't changing anytime soon.
Stop advising your suggested 'deactivate your plan and start again'. If the user is on AutoPay, this is an impossible task to perform without access to their account. You are providing useless information.
12-14-2018 12:49 PM
12-14-2018 12:47 PM
Unfortunately you won't be able to speak to any PM support any time soon, right now they just don't offer that service. May I suggest is to deactivate or close your acount and re-register as a new customer...I hope this helps
12-14-2018 12:45 PM
@ace065, I've seen this post, and your other post, and although I know you mean well, these folks can't access their account to deactivate, so they're going to have to wait for the Moderator_Team to respond to them.
You're new here to the community today, you'll get the hang of things. Please don't suggest options that frankly aren't available to the subscriber.
12-14-2018 12:43 PM
@ace065 wrote:Unfortunately we can't speak to a PM support..but the solution I come with is to deactivate your account and re-register as a new client get your orignal plan back or maybe pick a better plan..but if i have any other ideas I will post them...I hope this helps
PM support is accessible via private message. They will be able to fix this problem. It just takes time.
But yes...that is a workaround.
12-14-2018 12:39 PM
12-14-2018 01:51 AM
@Anonymous wrote:@chrissylatoya, did you try the Forgot my Password button/link?
@chrissylatoya if that doesn't work for you, please contact the moderator team via private message. They appear to be taking 2-3 days to respond to people currently, so you may be in for a bit of a wait. Messages are handled in a first come, first serve order. You can learn how to private message them here: https://productioncommunity.publicmobile.ca/t5/Knowledge-Base/How-to-Get-Help/ta-p/251745
12-13-2018 09:19 PM
12-13-2018 08:59 PM
It is just locked and said i need to contact administrators,not deactivate or anything they just need to reset so i can change my password
12-13-2018 06:07 PM
I just went to check in my account and all the us roaming are 10 days. If you need more you can just buy them there but you have to pay ever 10 days @lillian43
12-13-2018 06:04 PM
@lillian43 wrote:My phone says I'm suspended I don't owe any money but it said my time was up even though I don't owe until December 31st2018,I paid for my roaming also ,I really need my phone to work ,I'm visiting family in the USA,please help me
Hi i just signed up and it gave me the option to get service in USA for extra money and I was going to get it but they all said it was only for 10 days so I think you might have thought it was for the entire 30 days like me till I read everything! Glad I read all the details.
12-13-2018 04:46 PM
12-13-2018 02:42 PM - edited 12-13-2018 02:43 PM
@chrissylatoya wrote:I need my account to be reset at it is disable! How do get help! I have been waiting on a response nothing!
@chrissylatoyaIf it is a life-threatening emergency, or a crime is in progress, please call 911 immediately.
If this is regarding your cell phone / suspended / deactivated account / unable to make payment, data not working, why you need reset, etc then please give us more details and we can help you.
