Help
Ricky2Gunz
I just got my sim card in the mail and I already purchased my plan when ordered sim card and now I can't log in
2 REPLIES 2
Hassan9384
If you’re using a vpn try to disable it, the doesn’t work with vpn on
ORNGNBLK
@Ricky2Gunz  Welcome to public mobile! If you’re looking to set up your subscription fully, you will need to download the app and follow the instructions. You can’t do this from the website. If after, you are having trouble logging in to your account, try using a different browser or private/incognito mode, sometimes it’s a quick fix. Hope this helps
