Help!
Mosley85
Need to change the phone number to get the code? Used to set up
1 REPLY 1
Phil_Adelphus
@Mosley85   If you mean what I think you mean, log in to your account, tap "didn't get the code" to get it sent by email, once logged in go to your Eversafe profile and edit the phone number shown there.  Then the 2FA codes will be texted to the correct phone number in future.  If that's not what you meant could you elaborate?
