Help setup online
Aaden0809
Need help to reset the account online
2 REPLIES 2
Hi @Aaden0809, what exactly do you mean by reset the account?  Do you need to reset your password?  If so, there is a Forgot Your Password link on the login page. Try that out.  if you do not get a password reset email within an hour or two, you would need to contact the moderator team via private message.  Should that be needed...
Click here to send the moderator team a private message. Their hours are: Mon-Fri 9AM-9PM(EST) & Sat/Sun 9AM-7:30PM(EST)
You can find information regarding the moderator team by following this link.
--> If you have another issue, please provide additional information.
austinhuang
"Reset"? You mean password?
If so, https://selfserve.publicmobile.ca/ => Forgot your password. If you don't get the email within an hour or so, Ask a moderator (Can take up to 48 hrs, 1 message at a time) with these info on hand.
If not, please elaborate.
