08-22-2024 09:13 PM
We are heading to the US (from Canada), and hoping to use our phone for GPS. What would be a best add-on? We have no Canada-US text/roaming in our plan right now.
08-23-2024 07:30 AM
@FowlowFamily I use copilot GPS. Maps are stored on your phone. No need for data, your phone GPS works fine without it. Another that works is MAPS.ME
08-22-2024 10:21 PM
@FowlowFamily , you might be able to get by with the 250 Mb add-on if you turn off all the sync features on your phone and dedicate data to maps only. Google maps is so data rich these days, it could burn through data pretty quickly. I would not cheap out and risk being stranded in the middle of nowhere with no mobile data or WiFi, get the 1GB add-on and you should be fine.
08-22-2024 09:30 PM - edited 08-22-2024 09:34 PM
Here's what I'd do, @FowlowFamily
Download Google maps for use 'offline' to include the geographical areas you'll be visiting/traveling.
This way, you DON'T need a data plan. The maps will have been pre-loaded on your device and your device's GPS capability will navigate the same way.
The ONLY caveat is any real-time traffic conditions won't be available.
EDIT: you can use free wi-fi areas to browse or do any network-related stuff
08-22-2024 09:17 PM - edited 08-22-2024 09:19 PM
if you need GPS, you need roaming data. Get the Bundle (3GB and talk and text) for $30
But if you just need data for GPS and not much browsing, and only a short trip like 3 days, get roaming 1GB for only $15
