11-19-2019 05:18 PM - edited 01-05-2022 08:02 AM
Hi
I'm interested in a Dual SIM, phone from overseas. The manufacturer has given me the networks, it's compatible with.(below*)
Network:GSM900 FDD-LTE1700 WCDMA850 WCDMA1900 TD-LTE 2555-2655 WCDMA1700 FDD-LTE900 FDD-LTE 800 TD-LTE 1880-1920 FDD-LTE 2100 GSM1800 WCDMA900 FDD-LTE 1800 FDD-LTE1900 WCDMA TD-LTE 2300-2400 GSM1900 TD-LTE 2600 FDD-LTE 2600 WCDMA2100 GSM850 FDD-LTE700
Are any of these compatible, for 4G LTE service in Toronto,Ontario?
-Michael
11-19-2019 05:41 PM - edited 11-19-2019 05:42 PM
@geopublic wrote:Not a good choice. Calling will not work because it's missing bands 5 and 7 for 3G.
I think you mean it's missing bands 5 and 2 for 3G. Although the very first post says the phone supports WCDMA850 and WCDMA1900. So I don't know what to believe, but it's very risky to buy this phone.
11-19-2019 05:36 PM - edited 11-19-2019 06:33 PM
@M-Black wrote:OUKITEL C15 Pro+
Dual SIM Card and Dual Standby, 2G GSM 850/900/1800/1900MHz + 3G WCDMA 900/2100MHz + 4G FDD-LTE Band Band 1/3/7/8/20(800/900/1800/2100/2600MHz)
-Michael
@M-Black Not a good choice. Calling will not work because it's missing bands 5 and 2 for 3G. LTE is also missing band 4 that is very important for good coverage. Best coverage for an overseas phone is Umidigi A5 pro, F1, F1 Play and F2.
Edit to correct 3G band. Thanks @sheytoon
11-19-2019 05:29 PM
OUKITEL C15 Pro+
-Michael
11-19-2019 05:26 PM
@M-Black The reason why I ask is that I can look it up and give you a definite answer if it works for 3G and LTE.
11-19-2019 05:24 PM
The make & model, are not listed on the Public Mobile list*
-Michael
11-19-2019 05:21 PM
@M-Black What is the make and model of the phone?
