12-13-2015 01:34 PM - edited 01-04-2022 02:15 PM
I'm am former PM employee, happy with my service. I want to PM buy a phone and a plan for my son in Halifax. Will that work? Can he get a Halifax number? What would you suggest?
Thanks
Service
12-31-2015 12:01 AM
That's a very thoughtful and practical present. I wish more people would give gift of such nature over the holidays.
12-30-2015 11:51 PM
12-30-2015 11:49 PM
I did get the phone set up for my son in Halifax. Used my Old Galaxy 2 which still works fine and signed him for unlimited talk and tex Canada for $40 backs. He headed back to Halifax today with a phone. He hasn't had one for a while. GAve it to him as an xmas present
Thanks for all the help on here.
12-30-2015 08:07 PM
12-23-2015 11:28 AM
@Scoop 90 vs 30 day savings FYI: 90 Day Plan Savings
12-22-2015 11:46 PM - edited 12-22-2015 11:47 PM
Those are the different plan durations. You can choose either one, but generally the longer the duration the cheaper the average daily price of the plan. For instance 3 times the price of the 10 day plan would generally be more than the price of a similar plan of 30 day duration. And 3 times the price of the 30 day plan would generally be more than the price of a similar plan of 90 day duration.
Hope this helps.
12-22-2015 10:43 PM
Hi Guys
I'm tryingh to set my son's phone up. When picking a plan there is a heading to the left that lists
10 day 30 day or 90 day pass--What does this mean which one should I choose
Thanks
12-13-2015 07:38 PM
You're welcome. Good luck.
12-13-2015 06:45 PM
Thanks everyone for your help. I think I got it straight. May need some help activating the phone----we'll see
12-13-2015 04:12 PM - edited 12-13-2015 04:13 PM
@Scoop I can confirm that the Samsung Galaxy S III Mini, and the Samsung Galaxy Ace II X (sold by PM last summer) will both work on Telus' 3G network without a problem.
First step is to get a new SIM card (since you're in Ontario, you should get it within a week). When you're activating the SIM, you'll be able to choose what number you want. You can just select a Halifax number at that time without a problem.
EDIT: I guess I was typing out my response just as @Luddite was posting the one above.
12-13-2015 04:10 PM
@Scoop wrote:
I have a Samsung phone left over from my PM days that will work. So I just order a SIM card and sign it up. I plan on paying for the acct for the time being. How do I get a Halifax number attached. Do I have to start with a Local number? Ontario that iis? Any help APP
Yes, then just order a SIM card and sign up. Have not heard of issues with old PM account user names, however there have been odd issues with Koodo/Telus email addresses. So I suggest you use a different email address when you have received the SIM and are activating.
Concerning Halifax number, are you trying to use a current Halifax number? If not, when you activate you will be asked to choose a city and be offered several phone numbers; so choose Halifax or the nearest local area offered.
12-13-2015 04:03 PM
12-13-2015 03:57 PM
Anywhere Telus operates, PM does; check their coverage map on the PM web site.
You start by ordering a SIM (free) and getting a suitable phone. Try perusing these posts:
Where can I buy a phone to use with Public Mobile?
Get any Roger or Fido iphone unlocked for $13 to w...
Risk Free Activation - costs $10
Be sure any phone you get is compatible with PM network, is unlocked, or a Telus/Koodo phone.
As far as a Halifax specific phone mumber, I am not sure. Since the lowest plan includes provincial wide calling, that's likely not an issue.
Please ask any other questions that might help you.
12-13-2015 03:55 PM
Just to make sure I understand, you're saying you'd like to buy an older device that PM originally sold?
Or are you looking to buy any device, as long as you're sure it'll work with PM?
If the latter, then you can easily buy any Telus device and know for sure that it'll work on the PM network. And yes, your son will be able to get a Halifax number without a problem.
If the former, please note that a lot of the older PM devices were CDMA only, and will not work on the Telus 3G/4G network that PM now uses.
