01-22-2021 12:21 PM - edited 01-06-2022 01:54 AM
So i'm trying to get back my old number from when i last used this service provider due to that number being connected to several important accounts that require 2FA and a text message and when i signed up on a new account and tried to customize the last four digits of my number to my old number it gives me an error or says invalid?!?! Who can i contact to get this situation sorted out! Cause i need that number back!
01-31-2021 04:27 PM - edited 01-31-2021 04:30 PM
As others have said, the number may be gone forever. It might even already be assigned to somebody else.
Depends on how much time has passed. And maybe some luck.
Still, it doesn't hurt to ask Public Mobile what you can do, what they can do. Maybe the number can be reclaimed if it's still unassigned. Irregular but not impossible. Send a private message to @CS_Agent or have a chat about support tickets with simple Simon bot.
2FA = "Two-Factor Authentication" ... you (should) still have another way to login and authenticate yourself. So I'd recommend you login to those services and re-authenticate yourself with a phone number that is under your control. Before someone else does.
01-23-2021 12:58 AM
@Icemanjeremy902 : Ok. I was trying to nail down whether the account might just possibly still exist in that you wouldn't have to start a whole new account. But if you stopped paying over 4 months ago then the account would be gone. The new account might also have to have a different email address but maybe you're past that already. Sorry for your adventures.
01-23-2021 12:47 AM
I last had the number probably last year around there ended up loosing my phone along with all my photo's and important documents which are all also backed up on my iCloud i cannot access without 2FA which is linked to the number i lost along with the phone
01-22-2021 01:20 PM
@Icemanjeremy902 : But again...when did you last pay on your previous account?
01-22-2021 01:00 PM
So i messaged the Moderator and explained the situation. I am waiting on a response! I called the number and it said this number is not in service......
01-22-2021 12:37 PM - edited 01-22-2021 01:25 PM
There maybr a slight chance that you might be able to recover the phone number.
Send a private message to a moderator.
01-22-2021 12:36 PM
I like @Anonymous suggestion to call the number you're seeking.
If the call connects to person or voicemail, you're out of luck.
If it's unused, then maybe you can get it by contacting the Public Mobile moderators.
To contact a moderator, there are 2 methods:
01-22-2021 12:29 PM
@Icemanjeremy902 wrote:The number did come from this service provider yes!
Calling it? And when did you last have service here? How long has it been since you last paid?
01-22-2021 12:26 PM
@Icemanjeremy902 There is no guarantee you will be able to get that number back. If it was from another provider, nothing PM can do. There is a slight chance PM might be able to recover it if it is available in the number pool. You need to contact them to find out.
If you need to contact PM Customer Support Agent, Start a Chat to Create a Ticket OR visit the Get Help page.
01-22-2021 12:26 PM
01-22-2021 12:25 PM
@Icemanjeremy902 : Did the number originally come from here? Or a different provider? Have you tried calling the number to see if anyone answers?
01-22-2021 12:25 PM
@Icemanjeremy902 wrote:So i'm trying to get back my old number from when i last used this service provider due to that number being connected to several important accounts that require 2FA and a text message and when i signed up on a new account and tried to customize the last four digits of my number to my old number it gives me an error or says invalid?!?! Who can i contact to get this situation sorted out! Cause i need that number back!
@Icemanjeremy902 hi if a number was used on an old account and then closed then your number is most likely gone sorry
