Global message
zakhan78
Hi,  Does global messages can also be used to send texts to Pakistan?
As I tried but its says they dont offer.
thanks
zhadj030
When dialing to international numbers always do
011 exit code from Canada
The specific country code here Pakistan is 92
And then the phone number of the person you are texting
ech_786
Let's say your friend with Mobalink and had cell phone # 0300123456789 in Pakistan
from Canada
use 01192300123456789
there is no need to put "0" before 3
Clear?
Hi. What Txt option you have? IF Canada-Wide, then that is reason. BUT if U have Global Txt, then logically, U should be able to
zakhan78
What codes should I use before the cell no?
As I used 00192306 but I recived text from PM that it does not offer texts outside Canada.
thanks
ech_786
Haan jee...
it works for Islamic Reb. of Pakistan as well ..
