09-29-2022
11:58 PM
09-30-2022
12:07 AM
computergeek541
My phone calls a number (778-580-4001) every day once or twice, duration 4-7 seconds but sometimes more, once for 51 sec. This does not appear on the list of outgoing calls on my phone; I just discovered it by going into my Public Mobile usage history. It has been going on since at least early July and seems to occur every day but not on weekends. Is my phone hacked? What should I do? Thanks
09-30-2022 06:45 PM
Unfortunately, we all get spam calls.
If you block numbers, it will go to your voicemail box but the chance are the numbers are spoofed.
Better to ignore the call and not go to your voicemail box.
09-30-2022 12:20 PM
09-30-2022 11:39 AM
Thanks, that's reassuring. I guess the regularity of these calls means that my phone number has got into some robocall system that I just have to live with. In addition, I get a spam call every day or two (from a new number) that rings and I ignore (and then block) - these don't appear on the voice mail number and vice versa. Pretty weird.
09-30-2022 12:44 AM
@not-trust-anyon wrote:so why you moved my poster?
Your post simply repeated two other people.
09-30-2022 12:34 AM
09-30-2022 12:26 AM
I don’t know how to delete my post
09-30-2022 12:12 AM
I agree I will delete my post now
09-30-2022 12:10 AM
@noaccountpls wrote:You can try resetting your phone as new it could be a bug in your phone’s operating system. Or spyware from an app installed a your phone.
Please see my response above. Resetting the phone will nto help for this situation. There isn't actually anything to fix.
09-30-2022 12:09 AM - edited 09-30-2022 12:10 AM
@Nancy22
09-30-2022 12:07 AM
@BKNS27 wrote:Have you been calling your voicemail?
That is the number for PM voicemail.
Callng your voicemail would result in an entry in the phone's call log to that number. @Nancy22 Those calls from when someone calls you but gets sent to voicemail. They're not really outgoing calls. It's just the way Public Mobile records this type of activity.
09-30-2022 12:03 AM - edited 09-30-2022 12:16 AM
Have you been calling your voice mailbox or voicemail left in your voicemail box?
