04-20-2018 04:35 PM - edited 01-05-2022 04:39 AM
I let my plan lapse 2 days ago as I was switching to another carrier. My account says my account shouldn't expire till July, but when I called my new carrier to get my old number moved, they said it has already expired. Is there no way to get my old number?
04-21-2018 12:12 AM
You're going to reactivate your Public Mobile service on a plan. A phone number cannot be transfered to another wireless. So you'll have to make a payment to reactive the plan that you were on at Public Mobile. If you would like get the Public Mobile plan to something less expensive just for the purposes of getting it reactivated, you will need to contact a moderator.
04-20-2018 05:11 PM
@jp2 wrote:So mods can change your plan while in suspension but to change your plan with self serve you need to activate the old plan then you can change your plan yourself?
Correct only mods can change a plan while under suspension. I would never suggest someone pay what they owe to re-activate their plan to then change it in self-serve as they would lose out what they had just paid *Unless they are future dating the plan change* It is best to always go through the mods to change plans while service is suspended.
04-20-2018 04:57 PM
04-20-2018 04:52 PM
@jp2 wrote:My understanding is you have to make a payment of the plan you had when it went into suspension to reactivate the account
This isn't true. @kigall, if you add $10 to your account and then private message the mods and ask them to switch your plan to the talk and text plan for $10 that is all you should need to do to get your number active again
04-20-2018 04:47 PM
04-20-2018 04:45 PM
I simply found a slightly better offer elsewhere. What kind of payment would I have to make? Simply a plan?
04-20-2018 04:41 PM
I think if you make a payment to reactivate your account then you will be able to port it.
Sorry to hear you are leaving. Why are you leaving if you don't mind me asking
