Galaxy A54 5G phone users
WDThomas
Hey Folks, I'm a new subscriber to Public Mobile. Anyone out there using a Galaxy A54 5G phone?  Do I order a SIM card or is the phone eSIM compatable?
2 REPLIES 2
eddieO
@WDThomas I'm quite sure when you go into the app to purchase the eSIM there will be a spot there to verify your device is compatible, if yes then you should be able to proceed with the purchase. Public Mobile will then send you an email with a QR code to scan which will setup the eSIM on your device
BillyTran
Hi @WDThomas ,
Yes. The Samsung Galaxy A54 5G is compatible with eSim and as such supports eSim capablities.
Activate your phones eSim by following the instructions given to you.
I hope that helps.
Cheers
