Forgot password
06-27-2019 08:51 AM - edited 01-05-2022 05:36 AM
I forgot my password so I clicked “forgot password” I put in the email twice and then it asks me my security question, I answer it and it says “oh no something went wrong but don’t panic go back to login”
it nevers stops, I just can’t get into change my password.
I have a screen shot of my info so I know my security question is correct and if I DO put in an incorrect security question answer it tells me my answer is incorrect. So why won’t it accept my correct answer?
My Account
06-27-2019 01:31 PM
@Mel2019, do you have an email address like thisismy+email@something.com, rather than thisismyemail@something.com?
or, replace the + with an '_'? If yes, then it's probably the problem as the email system doesn't send to these types of accounts (it should... it's from back in the Arpanet days originally).
06-27-2019 09:23 AM
Good news. I would just wait to hear back from moderator. Sending multiple messages might had to the queue anyways.....
06-27-2019 09:11 AM
Thank you, I sent a pm to moderator. Afterwards I tried another device and my actual password worked! So no need to change password. Do I need to send moderated another message in regards to previous message or just wait to hear from them? I hate to waste their time:(
06-27-2019 09:01 AM
IF its the generic error you could
- try switching the language to french
- clearing browser cache
- waiting a couple hours
(the above should work with otther errors as well.
Mod reply time is taking over 48hours so it will take a while to get help from them, I would use them as last resort.
if you need to do an immediate payment you could buy a voucher and add it to your account by dialing 611
06-27-2019 08:58 AM
Thank you, I was on last night at 11pm and it did the same but I will try later tonight.
06-27-2019 08:54 AM
Try again incognito mode on chrome and if that fails contact a moderator at the link below.
https://productioncommunity.publicmobile.ca/t5/user/viewprofilepage/user-id/22437
06-27-2019 08:54 AM - edited 06-27-2019 08:55 AM
@Mel2019Public's system is glitchy.. Most of the time it is not your fault. I suggest you try it at off peak hours.. I personally usually prefer doing things like topping up / changing plans a bit after midnight. Oh if you are not already, make sure you are using a freshly started browser, with no privacy extensions etc to access the selfserve.
