08-04-2018 09:46 AM - edited 01-05-2022 05:16 AM
Hi all,
I forgot my password for my account and forgot password link is not working. I tried it by 5 days. Please help me. i also did a private message
Thanks in advance.
08-04-2018 11:11 AM
@Mehtab wrote:Hi....have you any idea when they will do it? Any time limit. The knowledge area says that they will reply you by 48 hours
It's hard to say. In recent days their workload was much higher than usual due to widespread renewal issues. I believe the problem has been dealt with, but there might be some backlog. All messages are processed on a first come first serve basis.
08-04-2018 10:30 AM
08-04-2018 09:56 AM
Thanks. I will try it.
08-04-2018 09:51 AM
@Mehtab, you will need to reach out to the moderator team for password reset. The moderator team can be reached via private message using this link. Please include in the private message account number and PIN code. Refer to the following knowledge base link for additional information on contacting the moderator team.
