Forgot my Sim Pin code
Kibowa
I forgot my Sim card pin code. Need help
 If you've never changed the code, it is 1234.
@Kibowa   did you entered it multiple time and got it locked?  Did you get a prompt asking for “PIN unlock key (PUK)” ?  If so, PM Customer support can provide code.  Simple use the Chatbot to open ticket with PM:
Type:  Unlock a phone
Click "Sim card PUK"
Click "Contact Us"
Click "Click her to submit a ticket"
After ticket successfully opened, keep checking your Community inbox (envelope icon on top right)  CS Agent will communicate with you there
@Kibowa
Explain your issue to Contact Customer Support Agent by  ,
they can solve your issue, they are nice Service Team they will help you 100%.
Here’s How To Contact Customer Support Agent by CS_Agent,
  • Get help with your account the easy way by starting a conversation with our virtual assistant, SIMon. It’ll take you to relevant help articles, or if it’s something more urgent, it can help you submit a ticket to Customer Support Agent by CS_Agent,Click Here link,to get started.
  • or you can send a private message to Customer Support Agent by CS_Agent, by Click Here link,
  • You’ll need to be logged in to your Community account for the link to work.
  • your account number,
  • your phone number,
  • your account 4 digit pin,>> you will say forgetting and they will Reset for you,
  • your Email address,
  • Customer Support Agent by CS_Agent, will Response to your inbox by private message
  • During business hours, we strive to answer customer messages swiftly. You will often get an answer within an hour. During peak periods, you may need to wait up to 48 hours.Customer Support Agents are available:
    • Monday to Sunday: 6 AM to 10 PM EST
         Good Luck...
