Forbidden A1 error
roughtimes
Just signed up yesterday and I'm getting forbidden A1 error after I enter in the MFA code.
My port failed as the result of me putting in the wrong IMEI,I would like to have this updated to the correct one.
2 REPLIES 2
Matt1278
I am having the same issue. I activated my phone it worked for an hour and now I can not get calls or texts. every time I try and login to my account I get the A1 error code I have tried for multiple days.
HI @roughtimes
let's try to get the porting issue fixed, and you will be able to login after
With that, PM porting support team can help.  I have sent you the porting support team number.  Please check your Community inbox (envelope on top right), check for the number and call
