11-27-2019 04:29 PM - edited 01-05-2022 08:10 AM
I requested to port my Fongo number to Public Mobile. The temp number Public assigned me is no longer in service and the number on my SIM is the ported in Fongo number. Can only make outcalls...no incoming and no receiving or sending text messages. Need help to fix this issue. Thanks.
11-27-2019 05:02 PM - edited 11-27-2019 05:03 PM
Porting a VoIP number will take up to 7 days.
FYI Number porting is a 2 stage process:
Stage 1. PM had don't it part of porting process by taking your Fongo number to set up at your PM account.
Stage 2. Now, you are waiting for Fongor to release you number to PM. Not until Fongo releases your number, all the incoming calls and texts will continue to go to Fongo.
11-27-2019 04:31 PM - edited 11-27-2019 04:33 PM
@trp101 wrote:I requested to port my Fongo number to Public Mobile. The temp number Public assigned me is no longer in service and the number on my SIM is the ported in Fongo number. Can only make outcalls...no incoming and no receiving or sending text messages. Need help to fix this issue. Thanks.
Incoming calls will not work unitl the porting has completed. The behavior you describe is normal behavior. Porting from a VoIP service might take about a week. To receive phone calls, you'll need to keep using Fongo.
However, outgoing text messages should still be working. I would check to see that the SMSC is set to +16475800172.
