Failed activation
10-24-2023
08:49 PM
10-25-2023
06:48 PM
computergeek541
Waited well past 5 hours. Phone still not activated.
We code didn’t work.
Don’t have the info to input manually
Sm-Dp & address
confirmation code
access code
Joining Public
10-24-2023 09:04 PM
I have same issue before, if showing sos only try couple time turn off/on esim and restart your phone, if still not work switch to physical SIM card will be faster option (you can find on Amazon for next day shipping).
Their customer support can really do nothing except a refund for 7-10 day.
10-24-2023 09:01 PM
You can only activate the SIM on the PM app on your phone.
If you are porting your old number over to PM. Leave the old SIM in your phone and wait for the text confirming with YES that you are porting over to PM…you got 90 minutes to reply or porting will be cancelled.
If you are picking a new number. Reboot your phone by powering off then power back on.
If you done all requirements and still not working. It could be a provisional/backend issue with the SIM then you will need to contact a CS_Agent at:
Staff hours are from 9:00am to 10:00pm EST.
