10-07-2019 07:35 PM - edited 01-05-2022 07:28 AM
I'm a new user but it's been four 4 hours since I activated and Facebook won't install. says oops something went wrong, try again later.
Joining Public
10-08-2019 09:12 AM
If both data / wifi give same error then it obviously is an app / phone issue
@jennieinthebarn wrote:I'm on Wi-Fi and have clicked data and same result.
10-07-2019 08:14 PM
@jennieinthebarn wrote:I'm a new user but it's been four 4 hours since I activated and Facebook won't install. says oops something went wrong, try again later.
Is your phone an Android? Try clearing all cache.
10-07-2019 08:10 PM
I don't think it's a network issue. Try to install it on wifi and see what happens...
If this doesn't work, try to go back to factory settings on your new phone and then try again
10-07-2019 08:05 PM
You could try Facebook Lite. I use it and it works great. It's likely a phone issue.
10-07-2019 07:52 PM
10-07-2019 07:51 PM
I am using Wi-Fi.
10-07-2019 07:42 PM
If data is working, I don't see there being anything about Public Mobile that would prevent you from installing an app. Does it install if you switch to Wi-Fi?
