FYI: enabling data on iPhones
s_bhshop
I'm a new PM customer and didn't find this info posted when I was looking for help enabling the data on my iphone.
Here is the website I used to download an APN profile:
Change your APN without breaking your iPhone (unlockit.co.nz)
This website enables data on your iPhone.
To use it visit http://www.unlockit.co.nz from your iPhone and follow the instructions on the screen.
2 REPLIES 2
Here is another article on iPhone and data:
https://productioncommunity.publicmobile.ca/t5/Phones-Hardware/FYI-iOS-and-APNs/m-p/323119/highlight...
In general, except for older iPhones, iPhone customers do not need to adjust APN settings.  It is automatic.  For iPhones 4 (and earlier), you will need to manually adjust APN as described above.
@s_bhshop
Glad you found what you needed to enable Data.  👍
Have you ever used the "Get Help" option at the top of the PUBLIC website?
You can find help articles. Here are some relating to APN: https://www.publicmobile.ca/en/on/get-help/articles?q=apn
