08-28-2021 07:12 AM - edited 01-06-2022 03:15 AM
Anyone else's phone adding an extra 1 to outgoing calls?
Service
08-28-2021 10:17 AM
Nope, dialing without extra '1'.
There were advises that some area codes do require extra '1'. Have not encounter such...
08-28-2021 10:04 AM
@ashleyskye : Is this a point of curiosity? I'm not sure why it matters. As long as the call goes through. If the 1 isn't included, the little confusing recording comes on saying you _may_ get charged. Which we don't. So enjoy the auto-1.
08-28-2021 09:58 AM
I just Google dialer and I believe it does the auto 1 in front.
08-28-2021 07:43 AM
@ashleyskye wrote:Anyone else's phone adding an extra 1 to outgoing calls?
This is not happening to me, but I recall something like this before.
Try one or more of the below:
*ensure your device has the latest software update
*uninstall your calling app, then reinstall
*perform a reset of your device's network settings
I thought it was something to do with that particular device's settings. So if you tried your SIM into another compatible phone, does it still do this?
