05-14-2020 12:30 PM - edited 01-05-2022 11:55 AM
I will be porting to Telus once I get their sim card in the mail, which was supposed to be today, but the tracking now shows delivery as tomorrow, May 15. My account is due: 'Payment Due Before: May 15, 2020.' Will I lose my number if I don't pay again today, May 14th? Or is there a grace period as I'm going to Telus? Thanks in advance.
05-14-2020 01:24 PM
I am thinking its the international sim that would be it right? As there is no spefic one for outbound sim to canada?
05-14-2020 01:11 PM
@kselmak wrote:I heard about that, there is a Hong Kong roaming sim, I've seen somebody use it I Toronto. When you have double sim phone it may be good option. I now forgot the details and how much it was, but I believe it was 'unlimited' fup was more than 40 gigs.
Do you know the name of it? Or a other name
Hong Kong 7-11 store
05-14-2020 01:00 PM
05-14-2020 12:48 PM
Best wishes
When your needs change again you know how easy it is to get back
And the same rule holds for the port back.
05-14-2020 12:48 PM
That makes sense but more me personally I would never pay $125 for the 50GB telus plan. Rather get an overseas sim that allows the data to be used all for roaming.
05-14-2020 12:45 PM
@Weslemlake ah understandable. Well sad to see you go have a good one! I have a friend that uses 80g and is with Bell because they gave him the best deal.
05-14-2020 12:45 PM
Exception is Telus/Koodo
You may need talk to customer service
They will be happy to see you come under the same roof
05-14-2020 12:43 PM
Thanks for help, leaving as require more data. Got telus' 50 gb Plan.
05-14-2020 12:43 PM
If with Telus you are fine
In-house transfers can be done even with expired account especially when you upgrade.
Make sure you remove your credit card or they will charge you at midnight
Sorry to see you go though
05-14-2020 12:35 PM - edited 05-14-2020 12:38 PM
quick responses! good job guys!
05-14-2020 12:35 PM - edited 05-14-2020 12:41 PM
@Weslemlake I think it does actually have to be active? Ill do a quick search and edit my reply if it is different.
Is there anyway we could convince you to stay? Why are you leaving Public?
So read through this article and it says the only caveat is that your account has to be active. Apparently they are not allowed to stop you from porting so as long as your number is available then it should not be a problem.
"If your account is closed due to non-payment, or you close the account yourself before porting the number, you will likely lose it"
So in your case you would be good if you waited until after 90 days it wouldn't.
https://www.cellphones.ca/cell-plans/p/phone-number-porting-10089/
05-14-2020 12:34 PM
Sorry to see you leave. But you don't need to make any payments or anything (just remember to remove CC from the account) to avoid autopay.
The account will get Suspended which is basically a hold. So when you do port over to Telus you can take your phone number with you on suspended account status. But after 90 days the account will become permernately deleted so no worries after you have left
05-14-2020 12:33 PM
@Weslemlake Sorry that you faced this.... enjoy Telus service, and no, you don't need to pay.
05-14-2020 12:31 PM - edited 05-14-2020 12:32 PM
Sorry To see you go @Weslemlake . The good news is that your PM account does not have to be active to port your number to Telus or Koodo. Stay safe.
