Everything wrong with PM
frank312
just actived my SIM and registed my account. but my iphone says NO SIM.....
checked with other phone, still NO SIM. SO I GOT a bad SIM Card.
my account is ACTIVE
then I want to change SIM, Fortunly, I brought two SIMs
BUT the web does not work,
Oh no!
It looks like something went wrong, but don’t panic.
I have tried use my laptop, my phone, my everything, still
Oh no!
what can I do now..
10 REPLIES 10
darcygibbs
@frank312 wrote:
thank you everyone
solved!
I changed the SIM
Were you able to get a refund for the broken one?
frank312
thank you everyone
solved!
I changed the SIM
frank312
I guess it's a broken sim card, so no phone can read this sim
@frank312 wrote:
Thanks
 I tried another SIM, it says NO Servies, not like the bad one which says NO SIM
@frank312What does it exactly say? "No SIM card Installed" or does it say "Sim Failure"  or "Sim Not Valid" or "Sim Not Supported" or.....................?
frank312
Thanks
@frank312Self serve is doing an update / has the common blank glitch right now, sometimes it takes a little time for the sim to become active during this common occurance.
If you just activate, wait a couple hours and restart your phone, most likely everything will work without having to change your sim.
frank312
I have tried, still does not work
but thanks
frank312
thank you, I will try
Dunkgirl
Oh no!
Oh no!
what can I do now..
@frank312
Currently my self-serve shows a blank plan page, which means you should wait and try again later. When you log in and see this blank.png
Then try to log in again, once it shows your plan then go ahead with your changes.
When all else fails send a private message to the public mobile moderator team. Click this to message them.  They will reply with a unique link to a secure online form where you will need to verify your identity as the account owner. After you’ve provided the verification please reply to the existing private message thread with the moderator. Read more about it here [ Learn about contacting our support team ]
mimmo
Try changing language to French. Try incognito mode.
