06-09-2024 09:45 PM - last edited on 06-09-2024 09:46 PM by computergeek541
How long does it take to get the new Esim when i change my phone to a new one
06-09-2024 10:36 PM
Yes, from the PM app go to "Account" and you should see "Purchase SIM card" where you can select eSIM. I think it currently shows it as being $5 but if you already have an eSIM I'm quite sure it will not charge you for another one.
06-09-2024 10:01 PM
You get an esim right away. Jus make sure you check that your phone is compatible with esim
06-09-2024 09:49 PM
I just download the app in my new phone and go to buy a esim?
06-09-2024 09:45 PM
@altautoinc wrote:How long does it take to get the new Esim when i change my phone to a new one
It's immediate.
