02-09-2024 05:17 AM - last edited on 02-09-2024 02:47 PM by computergeek541
I have a new phone on the way. This new phone doesn’t support esim. So I ordered a physical sim. Just wondering for when phone arrives in the mail, how do I transfer from esim to physical sim? I know it’s slightly different process then going from a physical sim to a different physical sim.
02-11-2024 02:30 PM
Yes it all worked out restarting the phone fixed had service showing
02-11-2024 02:26 PM
Excellent @Mohawk44
so all is good now?
02-11-2024 02:22 PM
It worked without a computer. I did the change via the iOS app. It’s all good now. So your statement about only using a computer is wrong.
02-11-2024 02:19 PM
I restarted the phone and service same back. It transferred to the new SIM card
02-11-2024 02:13 PM
Do I have to delete the esim or wait till transfer is complete?
02-11-2024 02:10 PM
It’s brand new. I haven’t gotten the device yet. I’m putting sim into my old iPhone. This way when new phone arrive I can just put sim in new phone. It’s the same iPhone I was previously using with an esim
02-11-2024 02:01 PM - edited 02-11-2024 02:02 PM
Can you test the new device with another known to be working SIM card to establish device vs SIM issue?
Did you purchase the device BRAND new, or used?
Where did you get it?
If used, check here for potentially blacklisted status:
02-11-2024 01:52 PM
I’m just getting SOS only
02-11-2024 01:50 PM
@Mohawk44 wrote:How long does transfer take? I have done this with other service providers and it wasn’t long. Just not sure with PM
Once you have the physical SIM card and make the request in your account, the process is completed instantly.
02-11-2024 01:48 PM
02-09-2024 06:24 AM
Yes, you can do it through log in your account. It is under profile. If you feel uncomfortable to do it yourself (I do sometimes because I don't want to mess up something) you can send in a ticket (respond within 24 hrs) to get PM agent to walk through with you. Good luck
02-09-2024 05:35 AM
Simply log into your self-serve account and go under your profile. There you will see an option to change the SIM card. Enter your new SIM card details where prompted and then insert the physical SIM card in your new device.
