Esim Activation Problem
SudBeau23
Hello,
Starting a new subscription and I am stuck on the final step of activating the eSim. Message says something went wrong. Have done all the Try Agains and now I am stuck on Step 3. What do I do now?
2 REPLIES 2
slusagm
You need to ask PM to help
 Since you cannot properly login, you won't be able to open the preferred Chatbot ticket. So, you will need to message them here: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
https://productioncommunity.publicmobile.ca/t5/notes/privatenote
hi @SudBeau23 @try reboot the phone and re-login app
if same, ask PM support agent to help
you can  submit by direct message:
