Error: ER05 "Invalid SIM card"
1337
Hello,
I put my fathers SIM card into a new phone and now it's giving me this error:
Important Notice
Your SIM card needs to be updated for Wi-Fi calling service compatibility.
The device is unlocked, it's the LG Stylo 4 model number LM-Q710MS and I've checked to see that it works with Public Mobile and it's compatible
Sometimes when callers call the phone it rings, sometimes it doesn't work at all, this is a Public mobile sim card issue, how do I fix it?
8 REPLIES 8
@1337
and if try all this and is still not working, i suggest you to factory reset,
how visit Here link
or Here link
@1337
can you try to reset network settings on an Android device
  1. Open the Settings app on your Android.
  2. Scroll to and tap either "General management" or "System," depending on what device you have.
  3. Tap either "Reset" or "Reset options."
  4. Tap the words "Reset network settings."
   or visit  Here link,
and go Changing APN Settings On Android device
click Here link,
Ensure you have the correct APN settings by visit Here link,
@1337 wrote:
it works in a different phone, but this phone is compatible with public mobile so it should work
and i turned off wifi calling, it still doesn't work, goes straight to voice mail, phone doesn't even ring
Yea...it's not a PM sim issue if it works in a different phone.
Keep playing with settings to see if that's the cause of your vexation..
Edit...where did the phone come from ? Did you get it on eBay or some such source ? Make sure your phone isn't blacklisted or reported as stolen.
@1337
are you sure your device is unlocked.
1337
@1337
first test your SIM card in another device, and is still the same issue,
Explain your issue to Contact Customer Support Agent by  ,
they can solve your issue, they are nice Service Team they will help you 100%.
Here’s How To Contact Customer Support Agent by CS_Agent, and Submit a Ticket
  • Get help with your account the easy way by starting a conversation with our virtual assistant, SIMon. It’ll take you to relevant help articles, or if it’s something more urgent, it can help you submit a ticket to Customer Support Agent by CS_Agent,Click Here link,to get started.
  • or you can send a private message to Customer Support Agent by CS_Agent, by Click Here link,
  • You’ll need to be logged in to your Community account for the link to work.
  • your account number,
  • your phone number,
  • your account 4 digit pin,
  • your Email address,
  • Customer Support Agent by CS_Agent, will Response to your inbox by private message
         Good Luck....
og2
Try resetting your network settings then restart the device.
Try contacting customer support agents
hairbag1
@1337 wrote:
Hello,
Important Notice
PM doesn't offer wifi calling...yet. Try that sim in a different unlocked phone.
