Error 837
04-30-2023 03:51 PM
Oops! Looks like something went wrong when activating your account.
Please start a conversation with our virtual assistant to create a troubleshooting ticket, and the next available Public Mobile Moderator can assist you in your activation via private messaging.
Note that you will need to create a Public Mobile Community Account to submit a ticket
For more information about Public Mobile support and how it works, click here
Error Code: 837
My Account
04-30-2023 04:37 PM - edited 04-30-2023 04:38 PM
@Sarasta wrote:How do I DM public mobile support?
@Sarasta , @softech gave you direct link to private message a CSA for help.
04-30-2023 04:33 PM
04-30-2023 04:00 PM
DO NOT try to re-attempt activation. PM might have charged you already.
Error 837 usually comes up when you request porting and used IMEI as the information for the old provider OR it has a problem with the credit card you provided
First check if PM charge your credit card yet.
Also, put the PM SIM in a phone and check if it connects to PM network and if it can make outgoing calls
If PM has not charge you and the sim card is not connecting, then the activation didn't completed.
You can try to activate again and request porting, but try to enter the account number of the old provider instead of IMEI. Also, confirm you put in correct information of your credit card
If PM has already charged you, then you need to open ticket with PM support and have them to sort out the activation and porting issue. Since you likely unable to login to My Account yet and open ticket, please open ticket by direct messaging PM support instead
