03-09-2023 02:12 PM
I WANT TO CHANGE EMAIL ADDRESS FOR PUBLIC MOBILE DOES NOT ALLOW ME UNDER EDIT IN PROFILE
My Account
03-09-2023 05:25 PM
unnecessary repetition that adds no value and no new information
03-09-2023 03:14 PM
03-09-2023 02:13 PM
HI @JC56 you are correct, only PM agent can change the email address for you
Please submit ticket at : https://publicmobile.ca/chatbot.
First type Forgot Login,
