Email change
Katyp
Trying to change email address to my daughters but will  it let me. So far it’s under mine. Any advice?
1 REPLY 1
@Katyp
as long as the email address was not used on any active Public Mobile account, then you can change the login email to it
login My Account firs, go to Profile -> Manage EverSafe ID and update the email there
or you can update it using the app, go to Account -> Manage Login (Secured by EverSafe)
