05-05-2024 02:39 PM
Hi. i subscribed eSIM, But It didn’t workding activate, So How Can I do? Do You send me my activate QR code?
05-07-2024 02:25 AM
I think I have Koodo postpaid, so Can I open the Koodo app? or Public Mobile app?
05-06-2024 06:44 PM
Yes I don't want
I want to my Koodo Mobile number(A)
OK I try it Thx
05-06-2024 06:43 PM
so, the account on the screenshot is NOT the number you want to keep? just the temp number?
if that is the case, can you confirm if you want to port a number from Koodo Prepaid or Postpaid?
if you have a Prepaid account with Koodo, you will need to open ticket with support for manual porting help. Please open ticket with PM support:
If you have Koodo postpaid, then you can just use the app, go to Account page and click Transfer Phone number and start the request there
05-06-2024 06:39 PM
So Now I have two canada numbers.
previous Koodo mobile, and Now Public Mobile
05-06-2024 06:36 PM
I see temporary number(B)
05-06-2024 06:30 PM
if you login to My Account, Profile page, do you see the "temporary number (B)" showing there? or the number you have before (A) ?
05-06-2024 06:25 PM
They give me a temporary number(B). So Finally I activate.
But I want to the number I was using before(A).
so How Can I Do? I sent CS_Agent. but not yet received reply
05-05-2024 03:35 PM
@Venny just put 19 zeros there
If unable to submit still, message support instead
05-05-2024 03:13 PM
And I can't Put the N/A
05-05-2024 03:12 PM
@Venny I don't think the PM eSIM was installed. Please open ticket with PM support as advised above
05-05-2024 03:07 PM
No, I use Iphone.
05-05-2024 03:04 PM
@Venny that is Android, what you see in Sett9mgs > Connection> Sim Manager screen??
05-05-2024
03:01 PM
05-05-2024
03:13 PM
yes. I can't show public mobile eSIM
Updated By Softech: Removed image for privacy
05-05-2024 02:59 PM
@Venny and nothing showing in the sim manger screen? or Settings > Cellular screen??
05-05-2024 02:56 PM
but I didn't receive the QR code in your Welcome email
05-05-2024 02:41 PM
don't give up yet, probably just one more step
Did you get to the eSIM installation step? Either the app will ask for your permission to do it for you, or you can get the QR code to install yourself.
If you missed the step to install by the app, there is a QR code in your Welcome email. Open it from a computer, or another device, then use your phone to scan it to install the eSIM profile on your phone.
Once you installed the eSIM profile, (or If you got passed that step eSIM installation step), try to reboot your phone once.
If it still does not connect and if you have another active sim on the phone, disable those non PM sim (eSIM/Physical sim) using the SIM Manager on the phone or simply remove the physical sim.
And make sure the one associated with PM sim and your phone number is enabled.
(On iPhone: Settings->Cellular , make sure the PM eSIM is set as Primary on "Cellular Plan Label" and "Turn on This Line" is toggled on)
Then click Reset All Networks on your phone and it will work. (Please note that Reset all Networks will also erase your saved Wifi and Bluetooth connections, but you just need to add them back after). Also, it is possible you have to reset it multiple times for it to work.
if it still does not work, Please open ticket with PM support:
