10-08-2023 12:29 AM
10-08-2023 07:07 AM - edited 10-08-2023 07:07 AM
Too blurry?
Try moving the camera slowly closer or further away until it self-adjusts for sharpness.
Depending on your device model, there may also be manual adjustments for zoom/close up which you can put in effect to allow a proper capture.
10-08-2023 01:18 AM
to install eSIM best is use the QR code you got from the Welcome email
Understand you mentioned about your camera is blurry, try to open the QR code on a computer, enlarge it and try scan again
I am not sure if support can provide you teh SM DP+ address, but you can try message them and ask
10-08-2023 01:08 AM
I need my sm-dp address and activation code for my esim
10-08-2023 12:57 AM
What eSIM details? the eSIM number? check My Account, go to Profile page
