Dynamic Autopay
argirovs
Hello,
I just wanted to know the difference between autopay and dynamic autopay.
Thanks
10 REPLIES 10
steff12321
@SD08 Ah my bad! Guess that shows how much I pay attention 😄
SD08
@steff12321 wrote:
It looks like they changed it after the maintenance this weekend to be called dynamic.
Pretty sure it was always dynamic, they just changed the wording.
@steff12321
Actually, they always had the word "dynamic" there in the account overview page, at least since I joined.  This is a snapshot of my page taken shortly after I signed up in Nov 2016:
One change they did make is to add the line "Payment for Next Cycle: $xx.xx" up top, just after the payment due date.  That wasn't there a week ago:
@argirovs wrote:
Hi there,
Thank you for your reply, but I still am not clear on this.
Does this mean that I will be charged according to my usage rather than my plan or is it that I will be charged the plan minimum plus any extra use?
Rewards and credits get placed into your Available Funds. Renewals will take from your Available Funds first and then if insufficient go to the set up autopay to get the remainder. Thus "dynamic". If autopay isn't set up then the account goes into suspension.
Edit: and if autopay isn't set up then those funds will stay in Available Funds.
And dynamic because rewards and credits could change.
@argirovs wrote:
Hi there,
No you don't have extra for anything with public mobile because it's prepaid. What you paid is what you have! What you pay is the cost of your plan. And perhaps some add-on YOU decided to buy.
steff12321
You will always be charged only what your plan cost is every 30 days. You cannot have any "overage charges", your service simply gets cut off, for example when use all your data, that stops working but you can still call or text.
The dynamic part of it means that if you have any positive balance for example from referrals or any other type of credits, this will be used in conjunction with autopay to determine how much is charged to your card.
argirovs
Hi there,
Lieux
@argirovs wrote:
Hello,
Thanks
Do you mean with that on the first page in your self-serve account?
  • AutoPay
  • You are currently registered for dynamic Autopay
  • Payment Due Date (One-Time Payment): Apr 27, 2019
  • AutoPay Amount: This is your plan cost minus Rewards. Any Available funds will be applied first.
steff12321
In either case, you will only be charged the difference between your plan cost and your current account balance.
Lieux
@argirovs wrote:
Hello,
Thanks
I think there is no difference...it's only 2 names for autopay in the self-serve account...??
@argirovs wrote:
Hello,
Thanks
Public Mobile only charges what is needed to pay for your plan at the time of renewal.  Some other carriers charge a fixed amount regardless of any leftover account balance that you may have.
